hey,
a little history, it's a 2jz with 1j ecu and emu (tuned via injector map), and originally i tuned it and it ran perfect with afr's at cruise and low throttle acceleration were around 14.7. but then the next day, it was like 12.8:1. and then today i had to go on a drive for 30 minutes, and it was 14.7 the entire way, but on the way back, it was damn 12.8.
so i'm figuring the only two things i can think of are the ECU temp sensor or the o2 sensor. but if it was the o2 sensor, why would it work perfectly one time, and not the other? and can i test it by just disconnecting the o2 sensor altogether, or will it mess with timing? i checked the temp sensor against the specs in the TSRM, and they're good.
anyone have any other ideas?
thanks
thanks
