afr
lian
58
ottawa
ok i got my maft upgraded to 4.8 and can adjust evrything laptop.
but even though i make adjustments on the maftpro it still does not change my afr wich is 9.9.
anytips.
i have lc-1 wide band could it keep the maftpro from adjusting
lian
58
ottawa
anytips.
the lc1 blue and white grounds are on the engine block and there is no green wire
americanjebus
Mr. Evergreen
wa.
^ first of all i can think of maybe 2 or 3 people that may be able to make sense of what you just posted. If you want help, ask clear descriptive questions with enough background so we know wtf your talking about and a more specific title for thread. Otherwise no one will bother to read your chatter.
Also you could try searching for relevant information and threads.
http://www.supramania.com/forums/showthread.php?t=11783&highlight=maft+pro+install
http://www.supramania.com/forums/showthread.php?t=60658
http://www.turboninjas.com/supra/maft/
http://www.innovatemotorsports.com/support/manual/LC-1_Manual.pdf
From what I gather you are running maft-PRO not just maft big difference and just got 4.8 software version to work, right?
Now you want to make adjustments with your laptop, but your changes dont do anything right? And for some reason you grounded your white and blue to your engine block?
-First of all you need to make sure you ground your lc-1 wires to the SAME place as your maft-pro.
-once your wiring is done you need to make sure your maftpro is reading the same values as your wideband, exact same.
-Make sure you have all of the correct initial settings for 4.8 AND make sure your laptop has the correct bin definitions for the version of maftpro that you are running on the PRO.
Once your MAFTPRO, lc-1 gauge, and laptop read identical figures you can begin working. To tune your car FIRST AND FOREMOST get your initial settings and turn off part throttle tracking and AFR tracking by setting the tps signals to zero.
That should get you started towards finding your problem. Your post doesnt have enough relevant info to really help you more.
lian
58
ottawa
thank you i will see if this solves the problem.
as for the blue and whit being grounded on the engine i read that off fullthrottle tech and seemed od too me.
the laptop works fine with emulation.
