I have the driftmotion aeromotive 1JZ FPR kit, + USDM 550cc
my issue is that given the amount of hose/pipe the FPR must sit above the heatercore outlet next to the brake booster...
problem is, I have moved my engine harness firewall hole to this area and it is quite cluttered already...
I deleted the cruise and tucked a bunch of dead leads where the cruise control used to be (under the clutch master cylinder)..
question;
1> any reason why it would be a bad idea to have another braided hose made up +24" so I could secure the FPR in that larger area...?
2> fuel dampener -- remove it?
3> FPR installs after the fuel rail...? as in fuel in on the firewall side, exits at the motor front, hardpipe makes the 180 turn to the braided, to the FPR, to the return line...-> correct?
also; I kind of dislike the driftmotion kit location because the FPR is placed basically top/centre of the firewall and I think I want to look stock-ish/discreet...
EDIT: found a photo, borrowed from; http://ns1.stanceworks.com/forums/showthread.php?t=15872
^same location just a little lower / custom bracket....
question;
