AEM Uego Mounting?
I wouldnt mess with that. Just get a self tapping screw or ground it to an existing body bolt to ground it. Then just pull off the cover to where the ign is and find switched power from the ign.. Its not hard and takes all of 5 sec to check which one is switched power...
Turbo Habanero
4,229
Tucson,AZ
ok by switched power im assuming you mean the it turns on and off with the car?
only problem is i don't have a voltage meter to be able to find the right wire...
