Jose(Soapra), This question is mainly for you since you've had success with the FIC.
At first it started fine with the FIC. I was pulling out of my driveway to head to the dyno and it stalled and car just died.
I plugged up the jumper cable and it ran fine. Got on the dyno, plugged up the FIC and car still did not start. I reflashed the fic and nada bro. MY take is that the unit is defective. I would assume that since the car runs fine with no issues with the jumper,that the wiring is fine. I tested by removing 1 cam sensor and then the second one while on the jumper and the Car ran. On the software I get no RPM signal.
Can you give some insight into what might be the problem? Or the unit is just flat out Faulty?
