p5150 said:
Maybe in some of the V8s and stuff the clearances are set bigger and the motor is built loose, but if you do it in this car you are asking for disaster.
There isnt any reason to make larger clearances -
nope
ask the high powered 2jz cars. Some run it. MOST do not. Off the top of my head, none of the Titan crew does, Larry from SP, Ryan Woon,. Ken Henderson I know does not. And those are the "all godly" 2jz.
The problem with knock. Great at shitty low levels. Raise the boost and it becomes worthless as now you are dealing with tons of motor noise and at 700+ rwhp, it won;t take much to knock the motor to death anyway.
