I want to let people know that the blow off valve that you get with the drift motion inter cooler kit needs some work done to it if you have compressor surge. What I did and it worked is get some permatex from advance auto or where ever. Next take the back of the bov off and remove the diaphram. Put a bead of permatex around where the diaphram fits onto the front housing. Place diaphram back on bov.Then pull the center black piece out which is where the check valve is attach to and take the o'ring out off the bottom and throw it away. Put a bead of permatex where the o'ring fits. Now push the black center piece back onto the bov. Let dry overnight. They are cheap and have alot of leaks inside. I believe the main problem was the black center piece is to loose causing the bov to leak and it could not build up pressure on the back side of the check valve. Keep in mind to put a small bead of permatex. Don't overdue. Hope this helps.
