Ive got a 7MGE block that I pulled from an 87 non turbo car and Im gonna be building it to replace my 7MGTE block that totaly screwed up after even being bored and new pistons put it but that a whole nother story. Well Im gonna put everything thats in the 7MGTE block in the 7MGE block. Except for the pistons which are bored 20 over but ive got the original std size Turbo pistons that came in it but I didnt know if I should go ahead and swap them into the GE block or should I keep the higher compression GE pistons in the block thats gonna have a turbo on it. I hope your following me. I just want to know if there would be an advantage using the GE pistons on a Turbo engine or should I go ahead and swap in the GTE turbo pistons?
The most boost this car would be seeing it 9psi and im not racing it or adding any upgrades anymore I just need it to run good and be fast.
Thanks alot
Danny
Thanks alot
Danny
