active tach/speedo idea...help me with this
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
it would be easier than building one, but it would require a total reprogram and wont be easy as "1,2,3, and 4". im not knocking the idea, just saying that it would require more work.
lagged
1991 1JZ
new rochelle
if you have the know-how :)icon_bigg ) it would be easier to design it your self.
i can think of a few cost effective ways to implement this.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
It would work on cars just fine without any reporgramming. What the shift indicator does it it just takes a ratio of rpm vs speed. One wire to the tach signal (0-1billion rpms) and another to a speed signal (voltage pulse signal). It saves the ratio between the two, so no matter what rpm or mph your at, you will always have a ratio. for instance if first gear is 1000 rpm for 10 mph, that's a 100:1 ratio. If your driving at 4536 rpm, your mph will be 45.36 mph. Always a ratio of 100:1. Second gear would be 1000 rpm to 18 mph, 95.8:1 ratio and so on with all the other gears. That's what the shift indicator keeps for every gear. Whatever ratio the shift rom sees, it displays that gear.
It's quite accurate and is the same setup used in the more exspensive systems, such as Motec, Stacks, and any other high end stuff. Easy as 1-2-3-4....
mkiiSupraMan18
Needs a new username...
United States
I thought ya'll were talking about making pie slices on the speedo showing the "shift points" for the diff gears...
First pie slice was green and went 0-30, so when you got out of the green slice you shifted... next slice was blue... 30-60... shift when u get out of blue....
I got a headache reading all of that. But I'm curious what the benefits of something like this could be... or is it more for the jdm tyteness in all of us?
lagged
1991 1JZ
new rochelle
i see a good money making product here actually...
and, all the customer would have to do is tell what the make and model of his car is and you adjust the high and low values accordingly, design the overlay or whatever for the speedo and thats basically it.
mkiiSupraMan18
United States
I mean, that would be a lot more K.I.S.S. than all the other stuff.
And if ya go that route, I'm only asking for 30% profit sharing :icon_razz
