AC oil - did i put in too much?
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
hey i just overhaled my ac system with a new expansion valve, parralell flow condenser, new compressor, and a new receiver as well as flushed every line and completely flushed the evaporater. however my air is not as cold as i would like with vent temps at 50 degrees when its like 75 outside. but i have a question as to how muc oil to put in. the system was completely oil free from flushing the lines and the new components. and the new compressor came with oil already in it. and the tsrm states to add 1.4-1.7oz for a new condensor, add .7oz for a new recveiver, and add 1.4-1.7 for the evaporator(cuz i completely flushed it oout. so i added 3.7 oz to the whole system plus the oil that was already in the compressor. im wondering if i added too much? how much oil comes in a new four seasons ac compressor? thanks
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
what refrigerant did you charge the system with, and how much? what are the outlet temperatures like at the duct farthest from the blower (driver side left of steering wheel), and what type of thermometer are you using to check the temps?
Raven97990
230
Georgia
www.speedforsale.com
How much did the compressor come with? Some come with enough for a full system some come with enough for the compressor. Also did you use refrigerant that had oil in it?
what are your highside and lowside pressures?
Sent from my X10i using Tapatalk
mdr40z
arkansas
did you vac it out and did it hold for a few hours?
sounds like there may be a leak still and that will get worse
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
vent temps are at about 53 while moving and 61 while stopped and thats at only about 75 degrees outside temps. :( pressures are around 30psi low and 215 high. this is with the engine at 1500rpms. at idle the low side pressure rises to about 50psi
refrigerant used was 12 oz cans of r134a. just refrigerant no oil in it, no stop leak.
i did pull a vac on the system for an hour. then turned off the vac pump and came back an hour later and vac read the same. i replaced all the orings and lots of components so i dont think there is a leak.
as for how much was put in, i am not sure. it took 1 1/2 340 gram cans so id say around 450-500 grams. oil was pag 46 and i put in 3.7oz plus whatever the compressor already had in it. ill try and find that out.
mdr40z
arkansas
right, add more freon, it can be 40-45 at 1500 rpm
high side doesn't matter as much and low side will spike, so it is the pressure when stabilized @ 70F @ 1500RPM
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Unfortunately there is no way to know how much oil in the system. The only way to know is to flush every component, remove the compressor and drain it, then put in the proper amount.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
So what is total "oil" volume for the AC System. The TSRM doesn't state a volume for the compressor itself, just volumes for the Condenser, Receiver, and Evaporator which adds up to 100-120 CC of oil, am I missing something here? Using passive context clues I'm assuming this is all that is needed.
Thanks in advance guys.
figgie
Twin Cities, Minnesot-ah
Zum
correct
but they are talking about a completely dry system (think replace ALL those parts with no oil in them).
So that is why good idea to flush the system and start from scratch.
Zumtizzle
Oct 21, 2006
2,825
Sac-Town, NorCal
figgie;1853053 said:
Zum
correct
Fig, yep dry system!
Adding A/C to a car that had it removed so everything is flushed, New Evaporator, New Expansion Valve, new O-rings, new oil, and charge. :D
Thanks 3P! So 120CC/ML is correct!
