ac compressor supposed to spin freely?
RiyadYar
384
NY
im in the middle of a bhg job and noticed my a/c compressor clutch was spinning freely and i thought their was supposed to be some resistance. So i bought a used one from a member and his spins freely also...is the ac compressor clutch supposed to spin freely .
mirage83
457
Georgia
IIRC the pulley should spin freely unless and until the magnetic clutch is engaged, then there should be resistance and the entire center section will rotate as well as the pulley.
8,900
You can turn the compressor by hand, it will be difficult. This is different than that free spinning part. In fact, when you install a new compressor, after filling with oil, you have to turn it by hand with grunt to circulate oil.
If the compressor doesn't come filled that is.
RiyadYar
384
NY
thanks guys. i still needed a new one because when i spinned the outer pulley it sounded like a bad bearing was in their
