? about cam position sensor rebuild/reseal
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I have. Piece of cake. I reused the gear though because owning a 20 ton press has it merits.
One place to buy the stuff: http://tinyurl.com/yq3tvp
Or you can get it for cheap from the outfits mentioned in 3P's excellent write up.
While you have it out cut a gasket for the CPS so you never have to mess with that O ring again. Might as well replace the cover and gasket too...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I did it as well. I had to buy the new gear, because I DON'T own a 20 ton press. It was a stone cold bitch to get out, too, if I had to do it again I might just buy a press!
Other than that, it was simple.
89blackturbo
Florida
I reused the gear without a press. Just drill the original dowel out, and i forget how i got the gear off. Hammer and a vice I think.
tonylr35
4
cumming
thanx ya'll. Got it done. The dowl did need to get drilled out. I didn't replace the gear. Came out petty easy. My cover also needed replace. I just used the Jetjock's link and got a complete kit from them. $25. Easy
