A340E and HP questions!
Isphius
Supra-less :(
May 30, 2006
359
long branch
cool! good info again! I plan on getting one of those giant B&M truck coolers and just strapping it to the radiator, that way it wont get too cold but still have plenty of overhead if need be. Im basically just gona get the tranny flushed and refilled and a new filter, and run the giant cooler. From what i hear i should be safe. Its basically gona be run off a stock turbo with IC pipes and a e inch turbo back. I expect it to boost right to FCO and make in the high 200s rwhp. I just want the trans to last long enough for me to get the r154 swap parts together! (maybe a year? 2 years)
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
toyo4life said:
Does any body else have this problem?
My trans takes forever to shift out of 1st or 2nd when the trans is cold. And when it does its a hard shift. once its been driven like 5-10 minutes it shifts fine.
Should I have the trans flushed? It only has 77,000 on it.
Mine does the same thing. I don't have a clue why. Anybody?
Oct 11, 2005
3,821
26
Thousand Oaks, CA
tookwik4u89 said:
I flushed out a spare stock oil cooler, and I run it inline with the factory/radiator cooler. Where it sits in my bumper, it's right out in open air. I built the trans about 4 years ago, and the fluid still looks new. Granted, I only drive it 6 months out of the year.... But it has seen at least 30-40 drag passes in the summer. I have basically the same setup as jdub.
Tk, do you have a picture of your setup? I have an extra stock oil cooler that I was going to rig like you have done. My original plan was to piggy back it on the existing oil cooler.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
if you upgrade your tranny they are meeaaannn... the most problems i have had with shifting is going from L to 2 to drive... tranny doesnt like it so i stopped doing it...
if you have any trouble with shifting... change the oil and filter. when you drop your pan check where the debris is either in the pan or the magnets in the pan will tell you what kind of wear your tranny is having. in my case everything was black and covered so it was pretty obvious since i couldnt get into any gear it was dead all around :):)
or upgrade cooling...
one of the best options for cooling is to run it through your rad and an external cooler (i bought a b&m cooler real sturdy design). it warms up very quick and stays cool
when i just had my tranny hooked to 1 cooler it would do what you guys said took a while to shift, once i hooked it to radiator and cooler... never again :)
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I dont have a picture of the setup, and you can't really see it here but its right in the hole outside the pass. fog light. When I had the stock bumper, I had it right in the open air in the front. I put the cooler downstream from the radiator.
[/IMG]
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
3p141592654 said:
Thanks. Did you plumb it into the stock rad cooler before or after your external cooler?
LOL, read my last post again;)
I figured since it would be cooler than the one in the rad, it would be downstream.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
from what i hear the tranny wants to be around 180 degrees and thats what i want my motor to be, so using the motor as a constant or almost constant 180 degrees as the last influence on the tranny fluid i believe it would regulate the temprature the best.
i see the radiator as a temprature regulator, if its too cold itll heat it up and if its too hot itll cool it down before it returns to the tranny. so by running it threw the external cooler first it removes all excess heat and gets the fluid to a temprature the radiator can deal with.
Thats why i set mine up to run threw the external cooler first.
maybe im just paranoid. lol i also plan to run 2 coolers. one for oil and one for tranny. both the same size and both as big as i can fit next to each other without overlap in front of the radiator, where the condenser used to be. then run a thermostat for even better regulation of temprature on both the oil and tranny fluid. i guess i am just paranoid....
Oct 11, 2005
3,821
26
Thousand Oaks, CA
That makes sense to me too. In cool weather it would seem possible to to bring the temp too far down since there is no thermostat.
TK, now I understand the comment on downstream. I was thinking you were talking about the air flow for some reason. :icon_conf
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
That may make more sense....maybe I will check temps some day when I'm running it just out of curiosity. I rarely see cool temps, driven in warmer weather mostly, and the track again soon. It's worked so well so far, I doubt I will change it.
Isphius
Supra-less :(
May 30, 2006
359
long branch
another question while all the auto guys are here....one...my OD light blinks on and off, is this like a CEL for the trans? what does it mean? two...what will a totally stock auto 88 targa top auto do in the quarter mile?
Yep...you have a tranny code:
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=AT&Page=13
An auto (equal cars) will usually do better in the 1/4 mile by keeping constant boost. Assuming the tranny is in good shape. Like I said, my auto tranny was built by IPT w/ a 3000 rpm stall. I launch by stepping hard on the brake and run the rpm up to stall speed. Instant boost off the line...best 1/4 mile I've done is 11.87 (my motor is not stock) ;)
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
I had no idea you were pulling that quick of an E.T.
What turbo are you using currently?
-Jeff
***annnnd, Edit: Nevermind, Decided to have a looksie at your profile after responding.***
I'm also using a piggyback tranny controller made by a company called ATK (JDM only) that moves the tranny's shift points. It works pretty well. The plan is to use the latest version of the SupraStick standalone tranny computer...I need to talk to Garret about the ability to integrate with the AEM EMS.
I have the earlier version of the SupraStick, but didn't install it when I found out it doesn't play well with an AEM. There's a work around, but just didn't want to deal with it, plus I got a hold of the ATK to play with. I'll end up selling the SupraStick I have now. I've just got to get the time (wife's "honey do" list keeps getting longer) to get the damn AEM installed.
I'm pretty pleased with the car...spools quick, runs good and plenty fast enough for me ;)
