A Sad Day
Status
Not open for further replies.
ians13
537
Jacksonville, fl
Well Today the day before my car goes into the shop for HG repair, it develops a knock right at 2500rpm not very loud but you can hear it. am sure it's rod knock my oil is clean changed 300 miles ago castrol syntech 10/40 with lucus, how did this happen with i know my motor has over 167000 miles on it but still man it sux bad. so i guess now i need a motor.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
cause the coolant might have mixed in with the oil. Rebuild it and your worries are gone ;)
ians13
537
Jacksonville, fl
well my Hg was not that bad it ran fine no smoke so over hears just bad cold starts and i checked the oil no coolant. well what ever the reason it's put me in a bad mood.
Mr.PFloyd
Jun 22, 2005
3,964
Supra curse man, Well if its a slight knock like you say (as if it just started) There is a SMALL possibility you can just replae the rod bearigns but i woudl get the crank machines to run 10 mm OS bearings all over.
johnathan1
Supra =
Aug 19, 2005
5,056
Ummm...how will replacing a head gasket, fix rod knock? You need to worry about them both while the engine is apart...why have a car with a good head gasket, but with rod knock?? And then have to tear it apart again?:confused:
Mr.PFloyd
Jun 22, 2005
3,964
yeah jonh is right... replace both at once. thats half the work later.
xXxICExXx
366
Abbotsford, BC, Canada
just get them to look at it while its apart, but dont fret over it, its not a big deal if your engine is already apart, that takes away half the cost right there of repairing the knock.
ians13
537
Jacksonville, fl
ok i am at a cross roads now rebuild the 7m but what of reliablity, depenability. am thinking about a 1j swap i would have to install it my self what parts are needed how hard is it to swap.
Mr.PFloyd
Jun 22, 2005
3,964
jesus. the reason you have a BHG is because the previous owner saw first signs of BHG then sold it to you. dont be stupid.
xXxICExXx
366
don't do a swap unless you are 100% ready for one and know every last detail about the engine and hooking it up. Fix your current engine, the least you can do is sell it in a running state.
Status
