A.r.p head studs on 7mge
supraman508
496
maryland
iv'e checked ebay for the a.r.p studs and all i see under it is 7MGTE.can i still use them for my 7MGE?I think i can but i want some feedback from supralovers that have allready used them.::dunce::
AJ'S 88NA
2,419
Florida
Yep they're the same.
supraman508
496
maryland
kool.know how would i tighten down the studs.would i have to use a vicegrip to tightly turn the studs into the block?what would i use to tighten them::dunce::plus i think by using studs it would make the lining up the head to slide right down in to place,instead of trying to line it up with just the new gasket and the little nipples that are on the block,right.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
there are dowel pins in the block that help you line up the head to block along with the gasket.
and arp head studs have a 5mm inverted hex into the top so you can use a 5mm allen to tighten them. but you need to chase the the threads to clean them out at least 2-3 times to make sure there clear of all of the crap from the OEM head bolts. and arp head studs go in "hand tight" which means dont crank them down with the allen...
gaboonviper85
3,236
Northeast Philly
You do not tighten the studs into the block....you screw them in with your fingers and that's it...put the head on and tighten the nut per directions!
Do not use any tools to install the studs.
Other than a chaser or a bottoming tap to clean the holes. ;)
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Alan;1250858 said:
Depending on the size of the nut you may or maynot need to grind down your socket so you can tighten down the nuts on the studs. Because of the clearence in the head.
Sears sells a deep socket, 12-point 14mm that has walls thin enough. Only costs ~5 bucks.
Craftsman, too so it has a lifetime warranty so you can be sure anytime your 7M BHG's itself, you will have the tool ready. ;)
dumbo
1,913
Albera, Too Far North
my mac tools dealer has one designed for toyota heads its on sale for 26 buck im picking up today. Just cause im sure i'll need her one day. Im sure snappy or blue point got one too.
supraman508
496
maryland
Thanks guys,if you click onto the thumbnail you can see antifreeze on the 1st and the 6th piston.Thats from lack of patients.I'm taking my time.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
i was able to shimmy a full size deep socket down to take care of mine. just needed to play with the cams a smidge to get the socket to fit.
supraman508
496
maryland
Thats an good and cheap method clip.i would'nt have thought of that.:icon_razz
supraman508
496
maryland
I also just took off the timing belt aswell since i'm changing the headgasket.plus i think the belt is atleast 10 to 15yrs old.Plus it has 2 rips in it.
