A quick question for those who make front facing intakes..
Blackmk3
142
New Zealand
hey im making my own FFI and im just wondering about the ISC, do i actually need it? factory computer..., or if i do can it be mounted on the back of the FFI or does it have to go in the middle to feed the cylinders?
advice would be appreciated :)
Nick
supra90turbo
shaeff is FTMFW!
MA, 01440
It seems as if selz is talking about the AFM. Not the ISC.
Thus, the importance of understanding the question at hand is evident.
lintlars
ROOTS RADICALS
Ft.St.John BC
You dont "need" it you could just crack the TB open a bit to help idle but it will cause for a higher idle when it does warm up your better off putting the ISC back on for smoother running car and it does not matter where you mount it it does not feed the cylinders its a contolled leak that helps you car idle smoothly mount it under the manifold where you cannot see it and route it back before the throttle body most TB have a large port where you can route back into
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
ummmm yea ISC is the Idle Speed Controller. LOL
AFM is what you'd be tossing if you went MAP/Speed Density
Blackmk3
142
New Zealand
ah sweet thanks for that i think that i will just stick with the ISC and put it on the back of the FFIM or on the side ill see how things go, thanks for your advice guys :)
Nick
Selz202
More than Regular Member
May 1, 2005
248
Black Diamond Wa
Cross posted from SF...
MKIIINA said:
depends. are you going to be running an AFM or taking the plunge into the world of aftermarket air metering? i am running the vpc on my ffim and am going to be keeping the isc but its not absolutely needed, you just need to adjust your idle higher than normal.
Im not even going to bother explaining it... i shouldnt need to as its right there in the quote. You guys should do some thinking before you post, why in the hell would i be talking about the afm? Ive been on this block long enough. There are so many advantages to speed density, that most people cant name most of them.
Tim
