hey guys needs some further insight.
my buddies 1jz isn't starting. cranks over fine but doesn't start. it was running fine before he went on vacation and when he came back it wouldn't run. all fuses and relays are fine. don't think fuel is reaching the cylinder.
tried to listen but couldn't really hear the fuel pump come on and i saw no Fuel pressure on the AFPR. i tried jumping b+ to the FP terminal and nothing happened. i ran a direct wire from the battery to the fuel pump connector and it turned on and fuel pressure jump up, tried cranking it with the fuel pump on and nothing.
pulled out my noid light and no injector pulse. sprayed some starting fluid in the intake and it sputtered and wanted to turn on finally. so it does have spark.
we tried another known working jza70 ecu, map sensor, FP relay, main relay and ignitor. again all fuses are perfect.
general info of the car.
mk3 supra
1jzgte
r154
mine's tunes jza70 ecu
stock tunes
370cc injectors
18 psi.
aeromotive afpr
any ideas or theories are welcome.
mk3 supra
1jzgte
r154
stock tunes
370cc injectors
18 psi.
aeromotive afpr
