A few questions
billspreston01
555
North Carolina
Ok, new questions, maybe somebody can help me with these instead of the old ones.
The differential makes a lot of noise at low speed and while cornering and low speed it's even worse. It's a rapid ticking noise. Also, the tranny (r-154) whines at low rpm in all gears. I'm running mobil 1 75w-90 in both the diff and trans. It seems like the noise coming from the diff is on the right side, but I'm not sure.
Also, I'm getting a lot of heat coming from behind the dash. My feet get really hot and the centerconsole where the cd player is at and all back in through there gets really warm.
I really need help with these things as I don't have tons of time to do a lot of work on it. Thanx
shaeff
Kurt is FTMFW x2!!!!
11
Around
code 51 is the TPS. it could need to be adjusted, or you might need a new one. here's the adjustment:
http://www.cygnusx1.net/supra/library/TSRM/fi/FI_101.html
code 24- Intake air Temp Sensor Signal
Diagnosis
Open or short circuit in intake air temp sensor signal (THA).
Trouble Area
Intake air temp sensor circuit
ECU
it could be a loose connection, or frayed wire, or a bad sensor.
-shaeff
