so here it is, my big idea. Lately I've been doing a lot of searching/researching on how to better performance and fuel economy, I've looked at pretty much everything, all the way down to solar panels to try to give some extra amperage to power some weird type of electrolosis machine. anyrate to water methanol injection. I remebered the 6-stroke engine concept patented by Jim Crower ( http://www.damninteresting.com/?p=467 ), and realized that the same thing could pretty much be accomplished without having to re-design camshafts and that. My idea is to baiscally add 1 more injector per cylinder (would have to come up with like a "v" type splitter to run 2/cylinder, and mount a second stock fuel rail). anyrate, the second set of injectors would inject water into the cylinders, and would have to either be significantly smaller, or have a shorter amount of time on the cycle of the water injectors. I think that this could work. instead of having a 6 stroke engine, it would be like an 8 stroke, or a cracked out 4 stroke. anyrate, the key of my idea is the firing of the injectors. perhaps take the original signal to the 1 injector, and split it into two, but adding some sort of flip flop type of relay, so that it alternates injector, and since pretty much every even cyindered engine always has at least 2 pistons firing at the same time, that could also be alteranted, i.e., say 1&3 fire at the same time, will now 1 will fire gas, and 3 would fire good 'ole water. To me it would save quite a bit of gas, add some extra power, clean out the cylinders, and keep engine temps down by a grip-which could mean more runs at the track or whatever.
I dunno, maybe I've been sitting here inhaling too much methane here or something.
Josh
Josh
