Heres a couple of things i've noticed...
After the car sits for a while (more than a day) it has a miss (i think? loud popping sound) for about 5 min.
I've only driven it 3 times since installation, and i continually notice smoke coming from the turbos, from around the heat shield
once the engine is running smoothly, it only idles at 400-500 rpm, revs perfectly to redline, but breaks up under load at 4000+ rpm.
today i pulled out coil packs and spark plugs, #1 was covered in oil, the others were ok, re gapped to .027
also there was a fine crack on every coil pack, right at the formation line.
What should i do? Im planning on epoxying the coil packs and heat shrinking, or maybe try plasti-dip, i've heard that has had success on healing coil packs, but idk about the oil.
any suggestions?
any suggestions?
