Quick ? My dads 91t is havin an ac issue. It's getting no power. If we run a wire from the + on the battery to the wire that's connected to the ac unit, it kicks right on and works. Is there a fuse for this?
it could be that you dont have enough freon to keep the low pressure switch on.
there is also a 25 amp fuse for the compressor in the right side kick panel. Yes thats on the passenger side. you have to remove the panel to get to it.
There are fuses also and a one specifically for the a/c clutch. My a/c went out and i noticed the clutch would not engage. i had just had the a/c charged recently so i knew a a/c clutch would have to have a fuse. I could not find it so i looked in the wiring diagram TSRM and found it.
