95 USDM 2jz & wanting to run aem
myfst89turbo
southern md
Ok so I just picked up a 95 USDM 2jz with a 6spd harness. My car is a 89 (gray plug)turbo 5spd. I want to run the aem EMS, but not sure how to get there. Do I order the 2jz to mk3 harness from tweak & run the 7m pnp or do I use my 95 harness & use the 2jz pnp aem EMS or maybe I just have this all wrong, someone please point me in the right direction for this set up
f00g00
586
Kuwait
Dr tweak can make your harness and sells aem so you could probably get a special deal from him, or wire in the harness yourself and get the aem from aaron at
driftmotion.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
If you hook the 6-speed harness into the car ( Via body plugs ) just like any other harness, you can then get AEM's jumper harness or... you can just get the 2JZ AEM ECU and it will plug right in.
