935 intercooler install
supra90mkiii
227
Racine, WI
i've gone through the write up on this, but i was wondering if i need to use a 1jz coolant overflow bottle? is there any other way to fit the ic up in there?
if not, where can i get one?
socc924
CT and Philly
I had no trouble fitting mine in without removing the overflow. It fit up pretty nicely i think. But I dont know which IC you bought, the medium or the large, because I have the medium.
935motorsports
San Diego, CA
You can use the stock one, but it does limit how high you can place the intercooler.
If using the 7m overflow, you should re-bend the bracket to place the bottle as high as possible, without hitting the hood.
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
or if your using a smaller battery than stock, slide it between the battery and the fender support (i use an optima). i had to move mine to install an IC block-off and new horns (stock suck anyway)
