89 vs 88
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
i was cruisin my neighborhood today and a nice lookin red mk3 pulls next to me, he was talkin shit and stuff and i said lets setle this over a race... jk jk. anyways my brother has a red 88 stock set at 9psi. i have a 89 fresh rebuild at 10 psi. raced from a 20 roll up to about 80 on a hilly straight rode. anyways i had him the whole time and pulled a good 6 car lengths on him, he says its time for a rebuild
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
Supra28;1381852 said:
Haha, that outcome was expected. What are your mods?
Stock with intake and mbc set at 10psi. I just did a stock rebuild on it though with mhg and arps. His is stock with intake but a tired motor 9psi. Both 5speed so he has lower gearing in the diff which helped him some. We both had fun lol.
2jz88mk3
GVRA
Do you mean durring your 20 - 80 from a roll you shifted 3 times while he shifted twice?
Or do you mean "lower gearing" as in his top speed is lower because of his higher geared diff?
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
i mean he should have a little quicker acceleration from the lower gearing, we only went to like 80 so his lower top speed didnt factor in
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
you forgot to post the rest of the story..
"after the race, we pulled into the gas station and both our cars started smoking and leaking coolant."
j/k..:biglaugh:
2jz88mk3
GVRA
Gear Ratio Terminology;1390007 said:
The terms higher and lower can get a little confusing when reffering to rearend ratios. If someone changes to a higher gear ratio they are actually changing to a numerically lower ratio. If you were to swap a 2.93:1 gearset with a 3.42:1 gearset you would be switching to a lower gear even though the ratio of driveshaft turns to turns of the wheel is higher. If you swap a 3.42:1 with a 2.93:1 you are switching to a higher ratio. I don't how high ended up meaning low numerically or low ended up meaning high numerically, but they do.
Apparently I'm mistaken.
