89 supra 1jz swap wiring need help (small Video) and pics
No those plugs are not right for the mk3.
What car did the motor come out of?
I'm not sure what car it came out of. One of the plugs looks like a jza70 plug but idk on the other. If it came out of a jza70 iirc there is a sticky on wiring at the top of this section.
supra1jz
284
Auburn, Georgia, United States
This plugs are from the 1jz body plugs what happen was I had the car running before but with all the wire that came off the front clip I got 3 years ago I had the car running on my other body if you look at all the photos on that link you will see that now I found a new body and rebuilt the motor cause it crank walked on me
supra1jz
284
Plus I don't need to use thos plugs just there are 2 wires one on each plug On the gray plug thers a yellow green and red wire that I need to know we're that one goes to in the 89 body plug on the white plugs there's a black and yellow and a red wire that one also I need to know what body plug it goes to
So are you wanting pinouts for the mk3 chassis plugs?
Idk what your motor is from so basically use an ohm meter at the wire in question and look for the same color wire and ohm those 2 points on the engine harness. Should get around .4-.7ohms.
supra1jz
284
does anyone know the pinout to this plug this plugs is all together with the Igniter
and it plugs into this plug
