89 NA tach on a Turbo 88 supra
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
i need to know how to get my tach working asap, what do i need to do, all the guages work but the tach
the cluster is a 89+ my car is a 88 supra, all plugs went in fine do i need to switch out my turbo tach elctronics in to the 89 cluster ?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i think thats the easiest way :)
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Yes, that's what you need to do. You can take the driver board from your tach and install it onto the '89+ tach.
NOTE: The instrument itself may have some variances. My tach now reads low, and if I rev it to an indicated 6,000 RPM, I'll hit the rev limiter, which I believe to be at 7,000 RPM. Therefore I never take my car over an indicated 5,500.
This is with an '89 NA tach with an '87T driver board.
When I installed the '87T tach with the '89NA needle and face, the tach would indicate 8,000 RPM at what SOUNDED LIKE 6,500.
Using a calculator for speed/RPM using the 3.909:1 diff and 225/50R16 tires, and using 4th gear (1:1 gearing) at speed (verified by GPS) indicates that my tach is now reading about 18% low, which is about what I expected, given the evidence. I did not run the same test with the other tach, though I still have it, and may try it again one day.
I surmise that the '87T tach may be balanced for the needle that came with it, and the '89 style needle has a different balance, which may be throwing the instrument off. This does not, however, explain the error with the '89 instrument, unless there's also a change in the driver board. I don't know for sure, but I'll eventually want to replace my tach with an accurate one. In the meantime, mine works, and I can "translate" it to reality fast enough for the only thing that really matters: Redline.
