89+ body harness pinouts
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I'm trying to find the pinouts for the 4 body harness plugs next to the ecu and the 6 or so that go to and around the fuse box in the engine bay. I've tried searching and came up short. Thanks.
Oct 11, 2005
3,822
26
Thousand Oaks, CA
2kV6 said:
It does a little bit. I'm trying to find the actual pinouts.
You can do it from the TEWD.
I'll give you an example....
Suppose you want the pinout of connector A35 (AC control servo motor) on page 24 http://www.cygnusx1.net/supra/Library/TEWD/MK3/manual.aspx?Section=Main&Page=24
So click on the Automatic A/C tab on the left side, then scroll through to p135.
At the top is a Parts Location table with a code column. Look for connector A35 and note that it is also designated H .
Scroll one more page and you will find a picture of the connector H. The function of the pinouts of the connector are in the actual wiring diagrams.
So on page 141 you see the "Recirc/Fresh Control Servo Motor" with pins 1 through 6 defined for the H connector (which is A35) and the wire colors.
Confusing yes, but after some practice its pretty easy to sort out.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Both of those definitly helped out. I saw those pinouts on ricks website and didn't put 2 and 2 together. So, I'm good on the us side body harness. I'm still trying to find out the ones that are at the chassis harness. I think its like 7 of them. Thanks.
