I have had some of this stuff done for over a year now, and it has been on a different site. Well in case the site I have it on ever goes down or away that would be very unfortunate.  I have a few more of these for 1jz stuff too. Thanks guys let me know if you need any help.
This is from a 1988 Toyota Supra Turbo with a Manual transmission.
B1 PLUG
1. Heater Water VSV-------------------------------- Black \ Yellow
2. L3 TEMS to ECU--------------------------------- Red \ White
3. L2 TEMS to ECU ---------------------------------------------------- RED
4. L1TEMS TO ECU ---------------------------------------------- BLACK
5. Check Connector for Fuel pump------------------------- Black \ Red
6. Circuit opening relay coil---------------------------------- GREEN
7. Goes to Start Solenoid----------------------------- Black \ Blue
8. Fuel Pump Relay on ECU------------------------------- YELLOW
9. Switched 12v For EFI From Fuse box- also +B check connector--------- Black \ Red Medium
10. NSW TO ECU -------------------------------------Black \ Yellow
11. Ignition switch to ECU-------------------------------- Black \ Orange
12. +12v for igniter, fuel injectors etc, resistor in engine bay -BIG Black \ Orange
13. A/C Magnate switch TO ECU--------------------------------- Blue \ Red
14. TEMS Check Singal----------------------------------------------- Purple
15. Theft deterrent horn plug on harness ---------------------------Yellow \ Blue
16. From headlight relay for Idle up, also comes to plug A1 ---------–Red \ Yellow
17. TO ECU injector 1 and 4 ------------------------------White \ Blue
18. SPD signal for ECT SPD signal for ECT ---------------------Red \ Green
19. Power Ground, also can be check at Check Connector---------- Brown
M1 Plug
1. Signal backup light switch ---------------------- Red \ Black
2. Positive for backup light switch Plus for Heater water valve VSV ------ YELLOW
3. Speedometer signal from ECU to combination meter ------------- PINK
4. Ignition signal to tech, from check connector to igniter------------- BLACK
5. Turbo indicator light signal for combination meter, also A1 plug------ Red \Green
6. ECU ground and Water temp gauge mass signal ------------ ---- BROWN
7. From pressure switch for oil gauge, also from ECU-------------- Yellow \ Black
8. W signal for warning light on dash ------------------------ Grey \ Green
9. Water temp sensor for combo meter----------------- Yellow / GREEN
10. From defogger relay also goes to plug A1 - ---------------------- PURPLE
B2 Plug
1. ABS plug on harness to transmission ----------------- YELLOW
2. ABS plug on harness to transmission --------------------- BLACK
3. ABS plug on harness to transmission-------------------- Red \ Black
B4 Plug
1. #160 A/C water temp s/w no. 2 --------------Blue \ White
2. A/C water temp switch ------------ Green \ Red
B5 Plug
1. Directly from HAC sensor ---------------- Red \ Black
2. Goes to AFM ------------- BROWN
3. Goes to AFM ---------------- Blue \ Red
A1 Plug
1. To defogger relay - ---------------Purple
2. To turbo indicator light --------------------------------- Red \ Green
3. Headlight Relay for idle up -----------------Red \Yellow
B1 PLUG
M1 Plug
B2 Plug
B4 Plug
B5 Plug
A1 Plug
