UPDATE: Well, I replaced my coil today, the old one was out of spec. BUT, that didn't fix it.
I've had time to verify a few things. I am not getting any codes. This is only happening when the car is warm. If it happens and I pull over and pop the hood for 30+ minutes it'll run fine until the temps rise again.
When this is happening the car will idle fine. The second you so much as tap the throttle it kicks and bucks and the RPM bounce all over the place. From the smell of the exhaust plenty of fuel is getting in... possibly too much.
My spark plugs, rotor and distributor have ~6000 miles on them. Replaced all my vacuum lines about 5 months ago. I've got 4 guage wire grounding everything under the hood (installed those lines about 4 mos. ago). I changed my oil about 2 mos. ago. I made sure my oil level is fine (check it very frequently).
I did just replace my radiator with a Koyo. Could it be dumping too much heat into my engine bay?
So, my thoughts are TPS, AFM, ignitor... Anythoughts?
