87 turbo 1jz body plug diagrams
armyastro
full body shave t04 mk3
Sep 16, 2005
222
radcliff ky
i have searched and searched for diagrams and have found some but they are for ones with a b3 plug and the one i am swapping does not have one. it has the square plug, 10 pin, 6 pin, 3 pin, all yellow and then a white 14 pin 3 wire. i wired the square IH1 connector but there is 3 wires left on the 1jz IH1 plug that are supposed to be put on the b3 7m plug but there isnt a b3 plug on 87 turbos. there is also a few others that are supposed to be swapped to the b3 plug but not able too. and there is 2 plugs on the 1jz harness i have not even touched yet, IH2 and a 10 pin grey plug does anybody have any insight on these two 1jz plugs and about the 7m plugs. there is no other place to put the wires from the 1jz? thanks
armyastro
Sep 16, 2005
222
radcliff ky
that is the one i used but it shows the b3 plug for which i dont have and it does not show what to do with the other 2 1jz plugs from the body?? the IH2 and the other 10 pin.. other than that this is what i went by and did all i could by what is on it. i am left with 3 wires on the 1jz IH1 square plug because of no b3 10 pin pps plug on the 7mgte body and a few small plugs and then 2 untouched ones from the 1jz...
armyastro
Sep 16, 2005
222
radcliff ky
ok i figured out the IH2 but not the 10 wire grey plug next to it i can figure out all the rest of the wires except that 10 wire plug and the abs wires/ a/c wires because of no b3 plug...
