87 Engine in an 89 Chassis?
2turboZ
73
Buffalo NY
Will this work?
As some of you may have read my motor is junk and I have a local guy with a full longblock out of an 87.
Will this plug and play with all of my 89 existing wiring?
Will the 87 take the same AEM EMS unit?
I did a quick search and couldnt really find the answer I was looking for.
Thanks
duffer26
74
Colorado Springs CO
i just put a 90 motor in my 86.5 and i just changed the harness and some sensors on the t-stat housing and as well as the distributor and that was all
i take that back i had to use my old injectors due to the impedance deference but all in all no big headache
2turboZ
73
Buffalo NY
Yeah I should clarify both are 7mgtes but I have AEM EMS
So just lop of and solder on the different connectors and i should be good to go?
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
ma71supraturbo said:
You can use the 87 longblock without any problems. You will just hook up your 89+ wiring harness to it (and sensors as some of them are slightly different -- like the CPS).
Since when has the CPS been different? The connector on the CPS never changed, nor did the part number for it.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Are you able to switch out motor mounts, or do you have to get the front subframs from the pre '89s to put one in a +'89? When I buy another supra to rebuild, if it's a pre '89, I want to have the beefier +'89 engine in it.
ma71supraturbo
Redding, CA
www.geocities.com
Hmm, good to know. My assumption stemmed from the fact that the 87-88 AEM ems initially had some issues with the CPS signal (while the 89+ version seemingly did not). This was the reason for the additional delay when releasing the '87 EMS 3 or 4 years ago...
ma71supraturbo
Redding, CA
www.geocities.com
You just use the engine mounts from your current engine. What is "beefier" on the 89 engine, by the way?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Thicker block, more ribs on it, better crank, better exhaust manifold, beefier all the way around. Check out IJ.'s side-by-side comparisons if you don't believe me...
2turboZ
73
Buffalo NY
Ok gang...I am gonna put the 87 engine in and take a year to machine and build a monster out of my 89 and next year switch back to the monster.
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
Generally speaking those changes happened for 1990, not 89, along with the newer crank. (Happened in 08/89 - model year 1990).
