Okay starting off I have an 86.5. I know that is crucial information because I guess the wiring is categorized into three sections. The pre89 does not cover 86.5; they're a separate entity?
86.5
87-88
89+
Someone can correct me if I'm wrong.
So this is what I did:
I cut the red/black wire from the fog light switch and taped up the wire going back to the dash. I then splice the one going to the fog light with my defroster's white/black wire.
Moving on to the fog light relay, there were TWO white/green wires going into the same socket....so I just spliced the fuseholder into ONE out of the two. I then sourced the wire to the cigarette lighter (15) and put a (15) fuse into the fuseholder.
So when I turned on JUST the foglights, it worked fine. They turned on independently from the headlights. So nighttime came around and then I turned on my lights...my left driverside headlight went out and so did the fogs.
I did not check the headlight's bulb or fuse yet so that is a bit unclear, but I'm assuming the fuse blew for the driver headlight as well. The passenger works fine.
As for the foglights, I checked the fuse and it blew!! So I put another (15) fuse in and turned on the fogs only. And the fogs worked again, but once I turned on the headlights the fuse in the fuseholder blew again!!
I haven't checked my headlight fuses but I'll go out and check it now.
Anyone have any info? Once again this is for a 86.5
Thanks in advance!
EDIT: went to check my headlights; took them off and found out that it was just the solder points on the harness that ripped off. so I'm assuming that is why my driverside headlight was not working.
my foglight problem still remains though =[
do I splice it with another wire from the relay or do I wire it with both the white/green wires?
86.5
87-88
89+
Thanks in advance!
