87 auto 7MGTE swap to an 84 manual.  Got the 7MGTE to start, sounds like it misses.  Runs and idles fine for about 7 seconds and then dies abruptly, sounds as if the fuel is getting cut.  If I give it gas, it revs to and tops off at 2000 RPM and after releasing the pedal it tries to idle and then dies immediately afterwards.  Thought it might have been the AFM, replaced it with a different one from a friend, but there were no changes to the symptoms.
I'm pulling a code 51, replaced the TPS with another one which was adjusted correctly. The previous TPS kept getting stuck in the open position. After replacement, I'm still receiving the the code 51 error. Code 51 also refers to a state with No NSW signal which lets the ecu know that the auto tranny is in park or neutral.
The starter is the original off the 5MGE to keep the wiring for the reverse light switch which might be the reason why it starts with No NSW signal. The NSW signal leads to the ECT ECU.
Checked voltage at ECU plugs. Everything is within spec except IDL which reads 6v with the IGN ON and throttle open. Spec is 10-14v
Jump Fp and B+ at check connector but still no differences.
Since the 7MGTE came from an auto, will the neutral start switch have anything to do with the issue?
Where is the neutral start switch?
Does this mean I need to hook up the ECT ECU in order to get the NSW signal to the ECU?
Why would the voltage be lower and what can I do to solve that problem?
Wiring diagrams show that the ECT ECU has an output IDL which interconnects with the IDL leading to the TPS could this have anything to do with the lower voltage reading?
The problem seems similar to having the AFM unplugged but I'm nothing getting a code for the AFM. This also makes me wonder, is there any one with a 7MGTE swap in Colorado?
Any help would be greatly appreciated!
