7MGTE Oil pump driveshaft bearings- No stock in North America
Supra Ev
31
Oakville, Ontario
North America is now sold out from what I've heard from 2 online toyota stores, 2 local dealerships and every aftermarket supplier for two local engine shops.
I'm in the middle of my rebuild waiting on those bearings to put everything back together. I have a set with 15,000km in my old block might punch those out and put them into the new block, but they've also been through the parts washer.
Does anyone know of any aftermarket sources or bearing mfg that might cross reference?
TIA
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
I have my 7mGTE motor in the machine shop now and they are replacing the bearings on the oil pump shaft as well. It is still a few weeks before they even start on it but once I get some info on it I will let you know what I find as a replacement.
You definitely want to change those bearings if you can. I pulled the motor on my 91 I just parted out and as the previous owner stated the motor was making a wired sound to it. Once I took off the lower timing cover I found the oil pump driveshaft gear had about 1/3 to 1/2 a inch of play in it. Here is some pics of it pushed it and pulled out.
