7mgte no boost/oil in intercooler
Al.R90
Nor Cal
What up everyone, looking for some help on this problem where I get no boost at all. I'm in the process of doing a boost leak test but I did pull some codes first. 12,25,26,51 came up I know the accordion hose needs replacing. I took off the other intercooler hoses and found oil pooling up on the side where it go's to the turbo and a lil bit on the side to the intake. Any help from the 7m gurus would be appreciated
Oil in the ic and pipes is normal.
Fix the accordion hose before going anywhere.
12 is the cps or wiring. The ne signal specifically which is used by the Ecu to determine engine rpm. Without that nothing runs.
25 is lean code
26 is rich code. Those could be o2 sensor.
51 is tps. Either try and set it properly or replace it and set it. Also make sure ac button is off when checking codes or that code will come up.
Al.R90
Nor Cal
Well the o2 sensor connector on the engine harness is missing, so the 3 wires have quick disconnect's on them what color's go to what?
