7MGTE MPG
themadhatter
760
Vegas
dok33 said:
Things must have changed since I left Blacksburg 2yrs ago, the left lane on I-81 used to run 85-90MPH, that was alot of fun in a lifted 4cyl 4-Runner :naughty:
they are really cracking down on 81 VA doesn't like speeders just look at the new va laws
The Evil Twin_7MGE
*edit* -gte
Oct 26, 2006
27
NJ
AaronsSupraMKIII said:
I'm getting around 13MPG. Is there something that needs tweaking? I was hopeing for at least 18 to 20. Its getting expensive driving to work and back every day. (50 miles round trip)
Im getting about 18-21 mpg between city and highway driving with a 4.3 rear end. Unless you're boosting the entire round trip, I dunno. I'd make sure timing, compression, tire pressure, etc are all in line first. From there it could be a fuel leak, exhaust leak, something you'd have to diagnose up close.
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
jetjock said:
Not to thread jack but yeah, VA Code 46.2-862 is a stunner:
http://tinyurl.com/2z3fjh
http://tinyurl.com/yvdsuv
tissimo
Stock is boring :(
Melbourne, FL
I get 19/20 in city and 22-24 on the highway depending how fast I run.. in my 87 w/ exhaust and a shitty filter..
AaronsSupraMKIII
254
Athens, AL
dok33 said:
OMG This picture rocks! I laughed my A$$ of! It is now my new background....
As for my milage. I am not boosting all the time. I do have a leak in between my AFM and Turbo. Could that be a contributer? As for timing, I really need to get it tuned on the dyno, just dont have the $$$ for it right now. Course I dont have the $$$ to keep spending $70 a week going to work and back either. LOL My tires say max psi is 44, I have them at 34. Is that to low? Just trying to ease the ride up alittle. Thanks for all the info.~Aaron
vas85
SupraNut
Sep 29, 2006
391
Sydney, AU
7Mboost said:
VA sucks banning radar fuck that, when I passed through there I got some many signals on my Escort, they must want new equipment.
in Aus its been illegal to have a radar scanner in ur car since I can remember... :cry:
Doward
4,245
Alachua, FL
IN other words, if you are passing through VA and a cop hits his lights, you want to run. No way in hell I would stop for a $3000 fine - I'll take my chances. :3d_frown:
Alang
55
Las Vegas
Further Update on my MK2-7mgte
Installed a HAC sensor (pre 89 harness). Car has had no HAC sensor since the 7mgte conversion. Put one in and instantly got 1-2 points of vacuum at idle and cruising. I also went from 4.10 rear to 3.73. No other changes, adjustments, or maintenance. Seems closer to what the car should be. Still can't turn more than 5 lbs boost.
Another LV-LA Road trip MPG report:
outbound 3200 rpm 90 MPH cruise 23.1 mpg
return 2500 rpm 72 MPH cruise 24.2
No A/C operation
Next Local 200 mile operation 19.8 MPG
Much satisfying improvement. The next thing to check is the ISC and CSI. There have been some small operating variances that suggest that they should be cleaned and checked. Will also be doing a Manual boost controller to check on the limited boost.
