Okay so here it is, my recently dropped new long block 7mgte idles great but sometimes if you rev it up and hold the throttle at around 2500rpm it sounds as if the cylinders are loaded up. The car occasionally puffs a nice big cloud of black smoke during a rev, not after. I've looked around on the car for any vacuum leaks but vacuum leaks would cause a lean condition. I've also noticed that the blue wire on my 3 wire o2 sensor is broken, thanks to the previous owner.:3d_frown:
So here's my questions, could the o2 sensor cause a rich enough condition to make it puff black smoke? I know the o2 sensor has no effect on idle. Also could the o2 sensor make the car stall when you push the clutch in? I do have a vented hks ssq bov and I know that causes the maf to get upset. The dashpot is also properly adjusted to make sure the throttle doesn't 'snap' shut because I had to adjust it so the bolt head would actually hit the dashpot push rod.:3d_frown:
Mods on the car are ct2657 on wg pressure, apexi intake and borla catback.
