So I replaced the HG, and not to jinx myself everything is fine, no leaks. I know the turbo to manifold gasket is leaky, I may need to tighten the bolts..
Anyways, it idles around 500rpm. When I tap the throttle, it almost wants to stall. One thing I know I didn't mark properly, is the CPS. Would adjusting this and my timing correct that issue? I sprayed around the engine bay with starting fluid and had no signs of vacuum leaks.
Looking for some input. Thanks!
