7mgte backfire
bosco659
Toyota nut
Oct 11, 2005
Canada
This has been haunting me for as long as I can remember but I thought I'd try to pick everyone's brain one more time.
My car continues to backfire when I shift gears. It actually backfires when I get back on the throttle after shifting slowly especially at low RPM's. If I shift quickly and over 3000 rpm, it does not backfire. Seems like a build up of fuel between shifts that re ignites.
I think it is worse since I installed my aluminum flywheel as the engine speed drops rapidly between shifts.
Here's the specs on the engine:
550's
Walbro and fpr
CT26 54 trim
15 lbs boost
3" exhaust with CAT
Lexus afm
BOV vented to atmosphere
Apexi SAFC version 1 - pulling up to 22% fuel at wot and full boost
Checked for vacuum, exhaust and intake leaks and none found
Reset TPS
Throttle linkage dash pot ok
AFR's 14.5 at idle and cruising. 11.0 to 11.5 under boost.
Can't recall fuel pressure
The only thing that I have never changed is the ECU.
Lmk what you think.
Thx
Mikael_7m
Built 7M
Apr 26, 2009
283
Australia
have you tried recirculating your BOV? backfires will occur when you vent to atmosphere. Probably not as much as yours though...
bosco659
Toyota nut
Oct 11, 2005
Canada
jetjock;1963826 said:
A backfire is an induction system event. Afterfire/muffler explosion involves the exhaust system. Which is it?
Not sure which one it is. I would assume that the muffler explosion would involve some flames? I have never had no one report flames from the exhaust. Would this then lead me to believe that it is truly a backfire?
Can you comment on probable causes of either condition? Thx
bosco659
Toyota nut
Oct 11, 2005
Canada
Poodles;1964128 said:
It's a muffler explosion and it's because you're running a vented BOV.
/thread
Thx. Maybe try to recirculate the bov over the winter. Car has always done this but now that I think of it I had always been venting to atmosphere when this has occurred.
