Hey I am getting a toyota supra with 7mge in it I have a 7mgte supra engine that needs a new head and some other parts. The supra I am getting is an 89 automatic 7mge engine. I have a 1988 7mgte 5-speed. i was wondering if i could use the 7mge head and put it on the 7mgte? i looked it up and some forums said that the heads are the same and if your going to run turbo/or big power you have to put the 7mgte cams for the intake. I understood that but I notice the the 7mgte distributor are diffrent than the 7mges. I didnt buy the 7mge supra yet but if i swap the heads can i use the 7mgte distributor on the 7mge head?And also they said that the 7mge engines are more weaker than the 7mgte, and because the 7mgte is ment for turbo it is built more stronger, so if i swap 7mge pistons would the pistons be able to hold up for the 7mgte?
