tissimo;1465749 said:Why so high? E98 or methanol engine?
Clip;1465763 said:wow! if i were looking into high compression, would i need bigger injectors to run these?
gofastgeorge;1465853 said:Here are my Cosworth 12.5:1 pistons.
Weight: 327 grams
Unfortunately they are no longer produced by Cosworth.:nono:
So if I ever want to replace one, I am screwed.
AJ'S 88NA;1465872 said:Geez Rich...first the billet cams and now this....I have to be careful about drooling so much, going to ruin my laptop![]()
gofastgeorge;1465924 said:Rich,
Are you going to machine the head where the 2 little nubs stick down between the valves,
or are you going to cut the piston back in that area?
suprarich;1466102 said:In flat big sky Texas you look at eveything from far away!
