7mge ct26
WyoMK3
28
Sonora, TX
I had mine done in a few weekends worth of work. But I had a turbo donor car. the cheapest way from where your at would be a gte exhaust manifold, downpipe and custom feed/ return lines. But dont expect it to live long, the NA ecu is not good to run with a turbo. short of doing a gte swap you basically need everything but the long block. some will say to swap cams too. but that's up to you.
