this may be a stupid question but...would a crank from a 7mge work fine in a 7mgte? are they the same? also would ge rods work in a gte or would it be best if i used gte rods? thanks for the help.
IJ. said:Both cranks are fully balanced but the later 7M crank has smaller counterweights on all throws whereas the early 6M style crank has larger counterweights and misses a couple of throws and will be harsher across the rev range.
IJ. said:Rich: I'd have the block checked for straightness in the tunnels first then line bore if needed.
Too many things can go wrong during the procedure to do it if it isn't required.
