7mge clutch and flywheel question
sas'd7mge
31
vancouver, b.c.
I'm swapping a 7mge into my 4x4 and went to get a new clutch so I could drop the motor in. When I got the clutch home, whe pins and threaded holes didn't line up. I ordered another clutch and it lined up...it was an 89 though. Are the 86.5-88 and 89-92 both push style? Or is the 89-92 a pull? I have a w56 tranny (same pattern as w58) any help would be great! Thanks
sas'd7mge
31
vancouver, b.c.
The part # for 86.5-88 clutch and 89-92 clutch was different and the pressure plate bolt pattern was different between the two as well so I just wanted to make sure that it is going to work. So there's no way the parts place could mix up a turbo clutch with an n/a clutch?
It's possible they have something screwed up. Seen it more than once, always funny when they try and argue with you that it will fit.
No differences in years that I've seen.
