Hi Everyone,
1)I am getting ready to do a 1JZ swap into my 87. However I wasn't given an engine harness with the 87 because I bought it as a shell. I do have a complete 1990 running turbo car. When I am doing the swap can I use only the plugs required from the 90 harness and still use my 87 dash and body harness or would I have to change those as well. Also if I could use just the plugs from the 90 harness without changing the other harness, what plugs would I need?
2) I was reading the soarer 1JZ wiring guide and I had a question When it says splice into, for example on the B1 plug, it says that into the green wire should be the brown wire from 1K2. Does that mean I should splice one end of a wire into the brown wire on 1K2 and splice the other end into the green wire on B1, or do I cut the green wire on B1 and cut the Brown wire on 1K2 and connect them?
Thanks in Advance.
Thanks in Advance.
