7m Stinger Thread
AndyMac
268
Canberra Australia
nosechunks;1350618 said:
im actually curious as to its controll and hook up aswell. i have little experiance with using this other then playing around with the software. i would imagine its under one of the outputs but i couldnt be sure.
BTW Andy your car is beautiful.
I will have a bit more of a look into it on the weekend and see if I can answer that question for you mate.
Thanks a lot for the comment :)
hopefully be more beautiful when its back on the road ;)
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Exellent that would be great. I know how you feel about having it back on the road I havnt driven mine in going on three years and hopefully within a couple of months that will change.
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
I removed a stinger 6860 from my car, i had to wire in a resistor to make the tacho work and i noticed the fools who hooked it up wired in a high energy igbt driver as well, dont know if they all need that.? I'll refit it into my car once i do a little more upgrading down the track.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Anyone make any tables for auxiliary inputs yet? I went with the 8860 but for some reason when i try to enter a number into the auxiliary input table it has to be a whole number or else when saved and reopened it will have rounded the number to a whole number.
For instance i made this table for the linear zeitronix output:
But when i reload the table it looks like this:
It does this if i reload the table or if i save the tune and reload the tune itself
It rounds the .5's either up or down and ruins the table.
Anyone else notice this or have this problem?
Im uploading the correct version of this table if someone could load it up and see if it works that would be great. Maybe its just my computer or software. Download and change extension to TRN to load into EMS software.
  • zeitronix linear.txt
Highnitro
Boostin' 4 life
Jun 18, 2007
267
Vancouver, WA
hey, i just got a stinger for my 7m and was wonder what u guys are running for ignition? im trying to wire mine to work with the stock ignitor and coils, but was wonder how to go about wiring it all up? do i just hook up the 3 ignition output wires to the same wires that the stock ecu used for ignition signal?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Yes but you need to hook it up threw a diode circuit for it to work properly. can be found in the other stinger thread, Type stinger thread in search and look in anything with stinger thread in title.
Mk3Les
Hey nosechunks do you know for sure if you have to do this with the plug and play harness that you can get from Driftmotion? I asked Aaron on twice and got a different answer both times?
Actually if any one has info on the plug and play harness could you please help an old guy out, either pm me or add it to this thread so others like myself who havent done this before can get a clue :)
Cheers
Les
