7M injector resistor box with 2jzgte question
turbogate
Life is Boost
May 18, 2005
425
South, FL
Hey Guys, quick question that has been confusing me. Using a 7M injector resistor box on a 2JZGTE has nothing to do with whether or not it's running sequential injection correct? In other words, using a 7M resistor box with a 2JZ will still let the 2J remain sequential injection and NOT convert it to batch/pair injection correct?
Thanks
crazysupra2JZ
740
Georgia
it will still run like normal. the ECU has complete control over the injectors. it's just drawing power from the resistor box when a signal is sent from the ECU. i'm using the 7MGTE resistor box with my setup. i've used it before on my previous 2jz/mk3 as well. or you can buy a 2jz resistor box from driftmotion, which is what i'd probably do, if you had the money.
p5150
ASE and FAA A&P Certified
Central Idaho
above post is correct - the injectors are fired by a switch to ground from the ECU and not by a 12v pulse. Since each injector is connected to a separate ground, they will continue to fire sequentially even if you hooked every single injector to the same 12v supply.
