7M-GTE? Swap
SilverBullet05
Project Paper Weight
Jul 9, 2008
7
Iowa
I have an 86.5 n/a 5speed i want to do a gte swap in looking at a 91 gte just want to know if it will bolt in, not sure about the mounts? Also the harness and ecu need to be the same your as the car or the motor any info helps please let me know thanks. Trying to figure out if it will all work before i buy the motor.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I've been trying to sort all this stuff out and there is one post you need to read abour 4 times over. Go to 7MGE tech section> STICKY> NA-T
you can also search 4cefed on google.
That will show you everything you need to know. If you still can't understand it, then ask specifics here, but most everything is covered well in that article. Gives you a shopping list and everything.
Please no one post all the info for him. ;) It's already well documented.
SilverBullet05
Jul 9, 2008
7
Iowa
That write up is excellent i have read it about 10 times and i know what i need so the only ? is will the 91 motor fit in my 86.5? or ar the mounts different? i dont want to buy the motor and not be able to use it.
EdT.Mk3
Sorta Secret Supra
Aug 21, 2008
157
San Diego
There will be some minor wiring things you'll need to deal with. The plugs from the door, a/c, the uh... interior lights(? that wire under the oh shit handle)... that's all I can think of for right now. I myself would na-t or get a pre-89 gte motor, just for ease.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
You should have no problem using your current 86.5 motor mounts on the newer engine.
To make wiring easier, you may end up needing to buy/trade the newer harness, ECU & related engine sensors for pre '89 harness, ECU & sensors. Other than that, the swap should be relatively painless if you follow the well documented write-ups on this forum.
SilverBullet05
Jul 9, 2008
7
Iowa
so basically i just need the pre 89 ecu and harness right sounds simply i guess i know they changed some plugs but that was in 89 right? The transition year or somthin where they had new and old plugs. So pre 89 and 89+ are basically the same? if so then shouldnt be to hard.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Eh, no. He won't have to mess around with the body harnesses at all. Only the engine harness.
Ugh. NO! '87-88 are the same, treat '89 as it's own year, and '90-92 are the same. READ over on www.4cefed.com. It's ALL there! :nono:
SilverBullet05
Jul 9, 2008
7
Iowa
yah srry thats what i ment 90 - 92 and 87 - 88 are basically the same cars i know what ur sayin and yah i will only be messin with the engine harness not body lol
EdT.Mk3
Sorta Secret Supra
Aug 21, 2008
157
San Diego
Sorry, I was referring to the differences between pre89, 89, and post 89. Not that he had to go about doing such a thing. It's more of a hassle to match up the stuff between the years, though not impossible.
