Hello I just bought my first Supra (7M-GTE) about a month ago and it had a slight sputter around 4k rpm and was building about 4 lbs of boost. Then it started running really fucky. I changed the plugs, wires, fixed boost/vacuum leaks. I can barely give it more than 25% throttle and if it tries to build any boost it will maybe get one or two pounds and then instantly lose it and start bucking until you let off the throttle. No check engine light or anything. Any help would be appreciated
Thanks
			Thanks
