7M-GTE fresh rebuild-Low RPM miss
oldfastpat
22
S.W. Michigan
After spending all winter rebuilding engine,cleaning and replacing misc parts. spent spring break installing engine.Great oil pressure,no leaks and started right up... then a low rpm miss. #6 plug a little wet. and twenty year old plug wires. replaced wires. no luck. No code (a bad afm) thats another story. Misses less if I advance timing. seems to miss intermittently at higher RPM 1500 - 4000. Any suggestion?? I can't think of anything else to check.
oldfastpat
22
S.W. Michigan
Removed cps an it was clean, checked continuity and resealed wires. readings are within spec. Going to check igniter today. during winter I checked connectors and rewired and solder any stiff wires or broken ends.I have a afm that drops to 3 @ idle but the miss is at most rpm.I want to go to maftpro but don't want to try to figure that out until I get this fixed.and I don't want buy a new stock afm. I will us that $ towards Maft pro.
oldfastpat
22
S.W. Michigan
NGK BCPR6ES @ .031.After many searches I have found #1 bad ISC,#2 spark plug wires (new) bad,loose on plug. #3 coilpack#1/6 within spec but when i pull plug wires when running # 6 plug wire has no effect in miss. So i used another plug and old wire, runs better. Set ISC with a little opening so now it surges. also AFM sometimes reads reads 3Hz steady at low idle on Safc. How many post until I can post for sale. I'll search...
